Diaphragm well pressure tank troubleshooting
Crystal Cook
TX
I have a Champion CM10050 diaphragm well pressure tank. Yesterday morning the pressure started going up and down (I don't know the terms- sorry) when the water was used (sink, toilet, shower, dishwasher). The water is coming out cloudy today. Help!
Crystal Cook
TX
My father drained the well and the hot water heater. The water is sputtering out (like there is pressure but no water) and the water is now rust colored!
Well going dry would be one potential cause. I am not a pro.
Crystal Cook
TX
So, today the water is almost back to normal (98% clear would be my guess), the pressure isn't coming and going either. On the flip side the PSI is reading 90 and the pressure is weaker than it use to be. We did have lightening strike the property a few weeks back. My dad seems to think it just created a clog of sorts.
I would replace the pressure switch and/or the pressure gauge. 90 PSI should not happen.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yeah you need a new gauge. 90 PSI doesn't sound right. It could mean you pump is not shutting off, which is why the pressure isn't "coming and going".
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
PSI is reading 90 and the pressure is weaker than it use to be...
If the pressure is weaker and doesn't fluctuate, then you may have a leak. Obviously, the gauge cannot be trusted. A quick check of the air pressure on the bladder will tell you.
LLigetfa is referring to the fact that the air pressure in the pressure tank will pretty much match the water pressure if the tank is not empty.
