Thomas Redness
Hi guys,
I'm facing an issue I need desperate help with. I purchased a house last year which had a few electric issues. Lights thru out the house would flicker now and then. A few months ago I went to the breakers downstairs and individually flipped each on off and then back on and then the problem seemed to have gone away. (Not sure if that is relevant). About a month ago, I added a computer and an amp to one bedroom, and everything was fine for several weeks, no issues. slowly the flickering came back and a week ago it got so bad (lights were flickering really hard, almost to the point of going out, and you could hear static). after a few hours of this happening on and off, my entire computer rebooted, TV shut off, and I heard a wired smoke alarm go off on the first floor (I don't think they are on the same breaker, but cannot say for sure). The bedroom next door had the TV reboot there as well.
Since then, the flickering has been bad, and the cable modem attached to the same outlet as the computer which rebooted has been going off a couple times a day and the computer rebooted at least once more.
I'm not an electrician. But logically, if this is happening on multiple breakers does it point to ConEd's issue? or not necessarily? I have ConEd coming out here sometime next week but am not even sure what to tell them to test for. Does this sound like a problem on their end or mine? And if mine, what can I do to attempt to figure out the problem in the most cost effective way possible?
Sidenote: a few days after problems started, I had work scheduled for my house. the first floor is now gutted, and the contractors said they would be replacing all the wiring up to that point, but if I wanted them to fix the problem in the upper floors with the flickering it can cost 10's of thousands of dollars if it involved tearing up walls to find a shorted wire or grounding issue somewhere.
I'm hoping the fact that I have issues on multiple breakers means it's an issue at the panel or on conEd's side but don't know for sure.
Anyway sorry for the long story... just looking to hear thoughts of someone who may have an idea on what steps should be taken...
thanks in advance
thanks in advance
