I have very limited space and the drain in the floor was preexisting. The trunk is a 4 foot long and 4†wide along with the main vent, everything off the trunk is 2". The clean out is on an angle because vertically I can't snake it in the future. The slab to joist is only 15â€
ALSO, just out of sight there is a vertical 2" cast pipe just below the plywood floor. I was hoping that I could connect a sleeve to it and a PVC 90%, then split off with a Y to pick up the washing machine and bath sink. Both the sink and the machine will vent separately up the wall and across the ceiling and pick up the main vent.
Is this even doable? I've been told the Cleanout wont pass and the washer and sink can not share a 2" drain.
Am I basically screwed?
