Design for easy removal of a PVB?
Discussion in 'Irrigation / Sprinkler Forum' started by fishkiller, May 27, 2008.
  1. fishkiller
    fishkiller New Member
    Jan 11, 2008
    I need help in coming up with a way to easily remove my PVB without having to cut the 1" PVC each time. What type of threaded connections can I use that will not leak? I can post a picture of my current piping if needed. Right now the supply comes out of my crawl space just above grade level, turns 90 degrees vertical to the PVB, turns 90 degrees horizontal out of the PVB then 90 degrees vertical back down into the ground. I have ball valves on both sides of the PVB with threaded PVC (male) connectors. The connectors are solvent welded to the pipe so I can't twist them off without breaking the pipe.
    I'll gladly scrap my current design for a better one.
    fish
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The only way I can think of to easily remove and replace plumbing parts is with unions, one on each side of the device.
  4. fishkiller
    Jan 11, 2008
    Thanks for the speedy reply
    I got the same answer at lunch today from a guy at the big orange box store - nice to have it confirmed by an expert here.
Similar Threads: Design easy
Irrigation / Sprinkler Forum Are There Any Hose Bibs Designed for Continuous Use? Feb 20, 2017
Irrigation / Sprinkler Forum Help with a Design Aug 20, 2015
Irrigation / Sprinkler Forum Designing a sprinkler system to put water on house during brush fire Jul 22, 2015
Irrigation / Sprinkler Forum Starting design - check my flow/pressure please Oct 2, 2011
Irrigation / Sprinkler Forum what do you think about this design? Jul 10, 2008
