Demolition Advice
Discussion in 'Remodel Forum & Blog' started by DIYlady, Jun 14, 2005.
  1. DIYlady
    DIYlady New Member
    Jun 14, 2005
    I have an old bathroom attached to my garage. I am removing the bathroom. I need to have the slab jackhammered, but I am wondering about the plumbing in the slab. There are cold water supply lines and a toilet & shower drain. Should I expect to have these lines damaged in the demo ? If the old toilet line is connected to the sewer (which I am not sure is the case) what do I need to do before / after the demolition ? The water supply lines are connected to my outside water and I have a shut off available for that separate from the house water. Any info would be appreciated.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    slab demo
    its probably best to find where the water lines
    go into the slab from the crawl space?? or basement??
    then cut and cap them off
    the drain line is not as critical.... I woudl guess that you can jsut break up the slab and follow that drain back to wehichever directioin it goes
    eventually its either going to find its way back into the house of find its way directly to the sewer....
    its just a matter of capping off the 3 ro 4 inch line with something
    like a fernco test cap or a pvc coupling and a plug which would work fine...
Similar Threads: Demolition Advice
Remodel Forum & Blog Demolition Advice Oct 15, 2009
Remodel Forum & Blog Best way of protecting banisters from harm during demolition May 20, 2013
Remodel Forum & Blog Looking For Advice on Waste/Venting for Remodel. May 21, 2016
Remodel Forum & Blog Big problems arise after bathroom remodel: advice needed May 8, 2014
Remodel Forum & Blog I need advice on sorting slate tiles. Which issues should I avoid? Apr 25, 2014
