...can't be right/normal. This is new install. Called Delta and sent a picture. They said 1) could be debris in the line. 2) installed incorrectly (that didn't set well with the plumber ) or 3) needs to be replaced. I tried removing this gray plastic "dome" thinking it might be a water saver. Delta said it was part of the diverter.
Water flow will have a "gap" somewhere else at any given time. It's not a consistent flow pattern. And the amt of water that comes out really isn't adequate for us. Definitely not what we're used to. My Jado tub faucet is 8 years old . The water comes out in a fat aerated (but not too aerated) stream. The water stream can fluctuate at will and/or with the a change in water temp setting and water pressure. Sometimes it kicks water out to the side. Sometimes it all comes together like it should (but doesn't stay). It's crazy and I'm hoping it's not the new "normal". Plumber took it apart and looked for debris. Delta is sending a new one but plumber said he expects it will work the same way. Water coming out in 2-4 separate streams (that fluctuate) doesn't seem normal to me.
Does this look normal? Hope not! Does it look defective or...??? Is there anything I can remove that will allow more water flow? I'm in the country. There are no permits to pull, no inspections or code. I just want a decent flow of water that is consistent and solid (no gaping areas that fluctuate.
Thanks,
Monica (who is actually NOT a new member but the site wouldn't take my user name & pw)
Thanks,
