Delta R10000 and R11000 question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Freddie, Jun 3, 2013.
  1. Freddie
    Freddie Member
    Dec 13, 2012
    Ottawa
    I'm installing both the R10000 and R11000 rough-ins in my shower. Just trying to figure out the correct stringer depths. The R10000 manual refers you to the R11000 manual when installing both.
    The R11000 manual shows distance from stringer to front of diverter bonnet on the R11000 to be 3.25" when in fact it is only 2.75" on the R11000 that I have. Not sure why the difference.
    Looks to me that the plasterguard on the R10000 should be flush with the finished wall. Is that correct? That seems to be the case in the R10000 manual but the R11000 manual shows the plasterguard behind the wall.
    Secondly, where should the face of the bonnet on the R11000 be in relation to the finished wall? Flush with it?
    Looks to me that the pipe from the R10000 to R11000 should be straight so shouldn't the stringers be the same distance back from the front of the wall? Sitting on my desk the ports align perfectly as do the front of the R11000 bonnet and the R10000 plasterguard.
    Sure could use some help here. This is really not very clear at all.
  2. hj
    faucet
    The "plasterguards" set flush with the finished wall. That may, or may not, give the depth that a display model shows, but will be within the faucet's "max/min" dimension.
  4. Freddie
    Freddie Member
    Dec 13, 2012
    Ottawa
    What about the R11000 diverter valve? Does the bonnet sit flush with the finished wall as well?
  5. jadnashua
    Did you buy the trim yet? IF so, temporarily install it and look at where the rough-ins need to be so you like the look of the installed trim. The min/max lines on the plaster guards only tell you that the trim will fit, not how it will look.
Similar Threads: Delta R10000
Plumbing Forum, Professional & DIY Advice Delta R10000 Valve - Basic Copper Piping System Design Nov 17, 2014
Plumbing Forum, Professional & DIY Advice Delta r10000 shower rough-in valve too deep in wall.... May 9, 2014
Plumbing Forum, Professional & DIY Advice Delta R10000 rough in valve questions and more May 7, 2012
Plumbing Forum, Professional & DIY Advice Delta MultiChoice, R10000-UNWS Mar 27, 2010
Plumbing Forum, Professional & DIY Advice Delta R10000 rough in question Mar 30, 2009
