Delta Multi Choice Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by markthomas1429, Feb 16, 2009.
  1. markthomas1429
    markthomas1429 New Member
    Feb 16, 2009
    installing a Delta T13490 Multi Choice Valve in a rental tub/shower .......new from Home Depot.....won't shut off..............help!!!!!!
    Yes I don't know what I'm doing
  2. CarlH
    CarlH New Member
    Feb 4, 2007
    Northern VA
    Did you do any soldering with the cartridge installed? If so, you might have a heat damaged cartridge. The key here should be the cartridge. That is what controls the flow of water. Check the O-rings and check the seats for damage and if they are in their proper place. Did you disassmble the cartridge at all? Lastly, have you installed the handle or knob and tried turning it? I'm not sure, but it may be possible that the stop that limits the travel of the knob/handle could be another cause if it is not installed properly. I think there should be a drawing included with that package what would help you identify the parts.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    I don't know how the set you purchased was packaged. T...indicates a trim kit.
    The R10000 rough in valve, by itself, comes with just a blank cap. The water will run continuously unless you purchase separately a plug.
    Now, did you install the proper cartridge in your valve body??
    Also, your model, apparently an old one, is listed on this "multi choice alert": http://www.deltafaucet.com/customersupport/alert.html
Similar Threads: Delta Multi
Shower & Bathtub Forum & Blog Delta Valve With Multiple Rain Heads May 2, 2016
Shower & Bathtub Forum & Blog Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body Feb 1, 2013
Shower & Bathtub Forum & Blog Delta Faucet R10000-PX Universal MultiChoice Universal Rough-In Valve Dec 17, 2012
Shower & Bathtub Forum & Blog Delta MultiChoice Universal valve body (R10000) and length of drop to spout Jun 3, 2012
Shower & Bathtub Forum & Blog Delta Multichoice univeral valve with stops Nov 10, 2010
