Delta dual spray touch-clean showerhead?
Discussion in 'Shower & Bathtub Forum & Blog' started by budseibert, Jan 23, 2006.
  1. budseibert
    budseibert New Member
    Jan 23, 2006
    I just got a Delta single handle bath valve installed in a new shower. It has a Delta "dual spay touch-clean" shower head (Delta RP28601).
    Everything seems to work fine. Except the shower head drips out a good bit of water after the shower is shut off. I took off the head and some water dripped out of the pipe but stopped after a dozen or so drips.
    The shower head seems large compared to others. Is this just residual water left in the head after the shower's cut off?
    I also notice that as the shower head is "emptying" after the shower valve is closed, if water is turned on elsewhere in the house the dripping gets a little quicker.
    Regardless, once the showerhead empties, no more water comes out.
    I don't mean to be a worry wart, but I had new copper lines installed under the house at the same time and have had some other problems (hammer, etc.) and I'm a little spooked by the quality of my install.
    thanks.
  2. jadnashua
    If it stops dripping, then the valve is not leaking. You should be okay. My unprofessional opinion.
Similar Threads: Delta dual
Shower & Bathtub Forum & Blog Old delta shower valve not working Feb 25, 2017
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Feb 14, 2017
Shower & Bathtub Forum & Blog Need Model Number for this Delta Monitor Feb 13, 2017
Shower & Bathtub Forum & Blog Delta vanity faucets - again Feb 6, 2017
