delta diverter
Discussion in 'Shower & Bathtub Forum & Blog' started by larryf, Jan 7, 2011.
  1. larryf
    larryf New Member
    Jan 7, 2011
    Texas
    i have an anti scald single lever shower faucet. when i turn it on water comes out the tub spout and the shower spout. when i push the diverter in it stops the tub spout. how do i stop water from coming out the shower spout until i push the diverter in?
  2. jadnashua
    Is this a new install? Did it ever work right?
    Is there a separate diverter valve? If so, it may need service.
    If not, the likely problem is that you used either cpvc or pex piping to connect the spout. This has a smaller ID and creates enough backpressure to force some water out the showerhead. Otherwise, there's something partially clogging the path to the spout.
  4. larryf
    larryf New Member
    Jan 7, 2011
    Texas
    it is a delta faucet and the diverter valve is part of the main unit, but has a pusn in stem. this has been going on since it was new and i have just put up with it. it is an all copper install.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Somebody didn't pay attention to proper distances between the spout and the showerhead or, the spout is plumbed with a restriction.
Similar Threads: delta diverter
Shower & Bathtub Forum & Blog Replacement Delta bath faucet/diverter Nov 2, 2016
Shower & Bathtub Forum & Blog Delta R11000 Diverter not diverting Sep 13, 2016
Shower & Bathtub Forum & Blog Delta Diverter Valve Bonnet Nut Removal Apr 7, 2016
Shower & Bathtub Forum & Blog Delta shower diverter knob leak - can water leak into wall cavity? Nov 13, 2014
Shower & Bathtub Forum & Blog How to repair Delta mixing valve (diverter stem) Oct 11, 2014
