Delta Brizo supply hose leak. Help Please!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jaret, Feb 22, 2008.
  1. Jaret
    Jaret New Member
    Feb 20, 2008
    Engineer
    Bothell
    I recently installed a new Delta Brizo faucet and discovered a leak at the hot and cold water supply hoses. I had Delta send me two new hoses under warranty, only to discover leaks in the same places. I am thinking operator error here, but if someone could take a look at the attached pic and confirm my suspicions, I'd appreciate it. Is the joint identified in the photo supposed to swivel?
  2. hj
    hose
    That should be the inlet hose and if so, there is no reason why it should have to swivel.
  4. Jaret
    Jaret New Member
    Feb 20, 2008
    Engineer
    Bothell
    You are correct, it is indeed the inlet hose.
    My question is, if I twist it when I attach it to a standard braded faucet connector, is that what is causing the failure? Or am I just getting crappy replacement parts from Delta?
  5. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I use a 20" flexible riser on my pressure-test rig to connect to the 3/8" fitting on stops. I often see leaks at that swivel location, but if you hold your tongue just right while tightening you can make it stop leaking. Lousy design, imho.
  6. jimbo
    jimbo Plumber
    You shouldn't be twisting that hose. You should connect the end to the faucet, the screw the supply onto the Delta hose, using a wrench on that fitting so it does not twist
  7. hj
    hose
    There is NO reason why you should have to twist it at all. The flexible supply line has a swivel on the end so you do not have to do anything with this hose except hold it in place while you tighten the nut. If Delta never expected you to swivel it, then why would they have to make provision for you to do it?
  8. Jaret
    Jaret New Member
    Feb 20, 2008
    Engineer
    Bothell
    So if I tighten it down to the supply line, it should stop leaking? I'd rather not order another hose from Delta, they are giving them to me for free, but it takes a while, and it is a real pain to re-install. It is a very-very slow drip right now.
    One thing to note; when I got the hose from Delta, the visible O-ring on the opposite end that connects to the faucet body was completely dried out and cracked - so I replaced it. I was wondering if the internal seal on the other end might be in a similar condition. How does this type of connection seal internally?
    Thanks everyone for your advice!
    J
Similar Threads: Delta Brizo
Plumbing Forum, Professional & DIY Advice delta vs. brizo Aug 24, 2011
Plumbing Forum, Professional & DIY Advice Quick-Connect Hose vs Threaded Couplers on Brizo/Delta faucets? Nov 1, 2005
Plumbing Forum, Professional & DIY Advice Help identify Delta faucet Jan 29, 2017
Plumbing Forum, Professional & DIY Advice Delta Tub Spout Installation Questions Jan 10, 2017
Plumbing Forum, Professional & DIY Advice Delta kitchen faucet sprayer diverter clip - need tips please! Jan 2, 2017
