Delta bath/shower valves "with stops". Not sure if I need "with stops" or not
Discussion in 'Shower & Bathtub Forum & Blog' started by JOHN_P, Mar 8, 2010.
  1. JOHN_P
    JOHN_P New Member
    Mar 8, 2010
    Milwaukee, WI
    I called Delta to figure out which version of their valve body to get. They said "with stops" is better than "without stops" because you can shut off the water right at the valve. That's all they had to say. Nothing in their product brochures or literature tells you what this stuff really means, and I've looked at a lot of it.
    Is there any benefit to being able to do that?
    I could see one advantage in that I could hook everything up, test it out, and then turn the water back off at the valve while leaving the rest of the house water on while I finish up things. Or am I seeing the purpose of this wrong?
  2. Terry
    Aug 17, 2004
    It's nice having the stops.
    When I was doing a lot of apartment plumbing, more like a necessity.
  4. JOHN_P
    JOHN_P New Member
    Mar 8, 2010
    Milwaukee, WI
    Thanks Terry, and thanks for all of the great advice you've made available on these forums!
  5. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Basically if your valve ever starts leaking or needs servicing, you can isolate it from the rest of the house via the shutoffs and still be able to use water in the rest of the home...which is important as it's not always easy to get a hold of a plumber. Some plumbers don't like to use valves with stops in them because they feel that by the time it is necessary to actually use the shutoff valves, that they won't seal properly anymore, but I don't share that opinion.
  6. hj
    I am waiting for replacement stems for some intergral stops because they ARE frozen and someone broke the ends off trying to turn them with a screwdriver. In the case of Delta valves, they are repairable without removing the trim plate, so I would not have access to those stops, or need them, for repair purposes.
Similar Threads: Delta bath/shower
Shower & Bathtub Forum & Blog Kohler Bancroft Bathtub Drain and Delta Bath/Shower Rough in Valve Apr 20, 2011
Shower & Bathtub Forum & Blog Delta rain can shower head install Yesterday at 7:12 AM
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Need Model Number for this Delta Monitor Feb 13, 2017
Shower & Bathtub Forum & Blog Delta vanity faucets - again Feb 6, 2017
