Delta 600 series copper tubes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tamlig, Jun 18, 2009.
  1. tamlig
    tamlig New Member
    Jun 18, 2009
    The 3 small copper tubes that connect the mixing chamber and the valve are leaking. Has anyone ever replaced these tubes? I imagine someone would need a powerful torch.
    I know the best thing to do would be to replace the valve, but I'd have to cut up a wall since there is no access door.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I've done a few in my day after listening to hj.
    Takes some patience but it can be done. Doing a lot of torching inside a wall to complete that task.
    Most times you won't be able to see what you're soldering either.
  4. hj
    tubes
    I have done many of them, even for other plumbers who have damaged the tubes. IT can be a daunting job, and not one I would recommend for a DIYer. One possible glitch would be if you have the "small block" body with the bottom center tube which has an offset in it. That requires a small tubing bender and great patience to get it right.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Torching those tubes would be just as time consuming maybe more than changing the valve out. The valve can be replaced without access from the wall. Become one with the sawzall.
    [​IMG]
  6. hj
    valve
    I would like to see you change a valve installed with galvanized piping through the opening in the tile. Even one with male adapters can require more than that to remove it, even though a direct sweat one could be inserted using just the opening in the tile.
Similar Threads: Delta series
Plumbing Forum, Professional & DIY Advice Help Identify The Model/Series Of These Delta Faucets Nov 16, 2014
Plumbing Forum, Professional & DIY Advice "old" 1500 Series Delta Shower Faucet/Trim Replacement Mar 23, 2014
Plumbing Forum, Professional & DIY Advice Adjust Temperature on a Delta Hot Tub Faucet 1400 Series Apr 11, 2009
Plumbing Forum, Professional & DIY Advice Delta 600 series shower/tub valve Nov 26, 2008
Plumbing Forum, Professional & DIY Advice Leak in a "Delta 400" kitchen faucet Jan 2, 2015
