Delayed Ignition
Discussion in 'Boiler Forum' started by droback, Jun 6, 2009.
  1. droback
    droback New Member
    Jun 6, 2009
    I have a oil fired utica boiler that experience delayed starts intermittently.
    I've cleaned fully, replaced the air tube assembly (which include igniters and nozzle), and filter.
    It starts ok sometimes but at times starting is delayed causing smoke and a boom from to much oil being dumped in the chamber.
    Last time this happened (about 7 years ago), we replaced the transformer which fixed the problem.
    Is there somewhere else I should look or just replace the transformer?
    TIA
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Transformer
    Electrodes
    Nozzle
    Primary & secondary air
    Draft
    Primary control
    Solenoid valve
    Oil Pump
    Pump coupling
    Wiring problems
    Voltage problem
    Combustion chamber
    End cone
    Nozzle line adjustment
  4. ijkl515
    ijkl515 Guest
    Juicy Couture belts
    Juicy Couture belts 2008 - Designer swimsuits from Juicy Couture belts Click on any photo below to see more belts styles from that group. We Offer 2,500+ Charms. Explore juicy couture belts.
Similar Threads: Delayed Ignition
Boiler Forum Triangle Tube Prestige Solo Boiler ignition issue - any suggestions Sep 29, 2014
Boiler Forum burnham alpine 105 boiler ignition issues Jan 1, 2014
Boiler Forum trial for ignition Dec 2, 2013
Boiler Forum weil mclain boiler with intermittent ignition Jan 25, 2012
Boiler Forum converting to electronic ignition Nov 30, 2009
