Delay in Toilet Water Refill, After Flush
Discussion in 'Toilet Forum discussions' started by sweetchic, Nov 24, 2007.
  1. sweetchic
    sweetchic New Member
    Nov 24, 2007
    A few months ago this started happening. I've done internet searches, can't find that this happens to anyone else.
    It's a 1-year-old Toto toilet in a house. I flush the toilet, it always flushes great, and then silence. As much as a full minute later the tank and bowl refill with water.
    What is the problem?
    Thanks.
  2. Terry
    Aug 17, 2004
  4. jadnashua
    One of mine did that for awhile, then started to operate normally. If you clean the screen, it may go away, or replace the cap assembly for about $3.00.
  5. sweetchic
    Nov 24, 2007
    what if I don't fix it?
    well, it's not inconvenient.
    Will it hurt if I just leave it alone?
  6. Terry
    Aug 17, 2004
    You could leave it, as long as it continues to fill at some point.
    The repair is less than $3 though, takes no tools, and takes less than a minute.
  7. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    It won't hurt anything, but if it continues, it may eventually fail to fill to the line, which will adversely affect the flush. The same thing happened to my Drake after about a year. It has the Korky fill valve. I called Korky customer service about where to get a replacement cap. They gave me complete troubleshooting instructions and sent out a free new fill cap. Nice folks. I replaced the fill cap in about 10 minutes; problem solved.
  8. sweetchic
    Nov 24, 2007
    A grateful fan
    What a great forum!
    Thanks for the quick replies!
    I will check out Toto's customer service options....
  9. boctok
    boctok New Member
    Oct 19, 2012
    virginia
    There is a small valve in the bottom of the cup where the float is. Debris can get caught in this valve and significantly slow the rate that the water drains from this cup, which keeps the float from dropping and opening the valve. You can check this by removing the top cap and the float. If you have just flushed the toilet and there is still water standing in this cup, the small valve is clogged. You can take a paper towel and soak up the water which usually will also take up the debris.
Similar Threads: Delay Toilet
Toilet Forum discussions Delay in toilet tank re-fill Mar 19, 2006
Toilet Forum discussions Bad float? Delay between flush and beginning of fill Jul 8, 2016
Toilet Forum discussions Delayed flush lever Aug 26, 2013
Toilet Forum discussions toto drake delay filling Oct 24, 2008
Toilet Forum discussions Drake: Delayed Fill Feb 25, 2006
