Delay before water turns on in stall shower
Discussion in 'Shower & Bathtub Forum & Blog' started by Zagnut, Jan 11, 2013.
  1. Zagnut
    Zagnut New Member
    Jan 11, 2013
    Randolph, NJ
    I have a problem with a two handle faucet on a stall shower. Recently neither the hot nor cold water turns on immediately when the handle is opened. There is about a 20 second delay. During that time some small amount of water trickles out and then the water flow suddenly becomes normal. This happens on both the hot and cold sides. The only change I have recently made was to install a washer on the hot side about 4 months ago to correct a drip from the shower head. I removed the valve stem and installed a new domed washer. That fixed the drip. Thereafter the shower worked fine. Now several months later I have this problem with the delay when the handles are turned on. At first the delay was not long, but it has gotten longer over the last month.
    It seems to me that after the shower is turned off the water must be leaking out of the line between the shower head and the valve. However, there is no evidence of leakage in the ceiling of the first floor below the shower. I am on a municipal water supply and have excellent pressure everywhere else in the house. I have stopped using the shower until I can figure out what is happening.
    The house was built in 1974 and has the original valve and stems.
  2. Tee_14
    Tee_14 New Member
    Jan 13, 2013
    Edmonton Alberta
    Sounds like it is your shower head. Take your shower head off and see if there is any delay.
  4. Zagnut
    Zagnut New Member
    Jan 11, 2013
    Randolph, NJ
    I did take off the shower head and there is still a delay. There appears to be no mineral build up in the shower head. However, just to be sure I bought another one. Same problem occurs.
    Is it possible for the water to back out of the pipe to the shower head without there being a leak in the valve? It doesn't sound logical to me. However, There is no evidence of leakage below the shower.
  5. jadnashua
    Depending on the valve design, an internal sticky part could do that.
  6. Zagnut
    Zagnut New Member
    Jan 11, 2013
    Randolph, NJ
    Thanks for your comments. I have come to the conclusion that I have to replace the valve. I have eliminated everything else as the cause. So even though I don't know why it is happening, I am convinced that the valve is the problem.
  7. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Check the faucet washers. It sounds like they may be loose or there is a piece of one floating around.
    John
Similar Threads: Delay before
Shower & Bathtub Forum & Blog Delay with hot water supply in shower Dec 9, 2014
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
Shower & Bathtub Forum & Blog Elbow before p trap. Apr 21, 2015
Shower & Bathtub Forum & Blog Leaking valve in shower - Have you seen this type of valve before? Nov 8, 2014
Shower & Bathtub Forum & Blog I Need Advice Before I Tile Shower Jun 25, 2014
