Deep well seal & conduit identification
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by croghanite, Aug 31, 2013.
  1. croghanite
    croghanite New Member
    Dec 27, 2010
    South Carolina
    The galvanized conduit coming out of the seal is the house supply. What does the pvc conduit go to? Is this for venting?
    I need to loosen the seal so I can shock the well including the casing. I want to make sure that's not a 5' long vent pipe that's going to drop in the casing when I take the seal off!
    Secondly, Is this a two piece seal? If I loosen all four bolts is half of this thing going to fall down?
  2. croghanite
    Dec 27, 2010
    South Carolina
    BTW, The well was drilled in '98. is 220' deep with a 30' static level and an 8 yield. It's marked on the name plate.
    Is that good? I calculate needing to dump 1.5 gallons of bleach in my system to shock the entire house. 280 gallons in the well, 50 gallon hot water heater, 30 gallon tank, 10 gallons for the lines in the house. 2ppm of bleach.
    Is that right?
    I'm going away for a week and I plan to let it sit in the system all week.
  4. Harold Crawford
    Harold Crawford New Member
    Sep 22, 2013
    Michigan
    Getting cap off to pull lines to replace fpot valve
  5. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    The pvc may be part of an emergency hand pump.
Similar Threads: Deep seal
Pumps and Tanks Well Forum & Blog. Water is life. Remove Well Seal on a Twin Pipe Deep Well Aug 4, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Sta rite 1hp vertical deep well pumping but not building pressure. Jan 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. How to repair Goulds deep-well pump Sep 24, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New submersible deep well installation Sep 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Should I Winterize my deep well pump? Aug 20, 2016
