Deep Well Question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Alex12, Jul 23, 2012.
  1. Alex12
    Alex12 New Member
    Jul 23, 2012
    Mexico
    Hi everyone. I have a question I can't seem to solve by my self.
    I'm prepping for when the SHTF and as you know water is key for survival.
    I have a water well that about 380 feet deep and has a submersible pump connected which is working. I dont want to rely on this when the SHTF because I don't know if we'll have electricity. I don't have much money so buying and installing a hand pump is difficult. I want to use the bailer bucket method but the current installation has the drop pipe right in the middle of the 8" casing. I figure I have about 2 o 3 inches around the drop pipe to fit a slim bailer bucket although I don't know if it will get stuck on the way down.
    I guess my question is: Can I move the current drop pipe to the side to make room for a bigger bailer bucket? Keep in mind this is a 380 feet drop pipe which should be pretty heavy. (There is no pitless adapter).
    Please, any help is kindly welcome.
    Alex
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You are just asking for trouble. That bailer or line will get tangled or stuck with the drop pipe and pump wire, then S will really HTF. If it gets that bad the first thing I would do is pull the submersible out. Then you can use a larger diameter bailer and get more water per run. At that depth you are not going to want to make too many trips. Probably use some of the drop pipe to make a tripod, so I could hoist the bailer with horsepower or kidpower.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    If you are seriously concerned about when the SHTF, i'd seriously consider a generator. When fuel runs out we have a serious problem!
Similar Threads: Deep Question
Pumps and Tanks Well Forum & Blog. Water is life. Deep well Jet Pump Questions Feb 21, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Questions about air in supply lines and deep well Apr 5, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Deep Well Single Pipe Packer - Jet Pump Priming Question Aug 6, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Deep well pump pressure tank question Jul 5, 2011
Pumps and Tanks Well Forum & Blog. Water is life. deep well questions Aug 21, 2009
