BadDad
Hi Guys,
I just purchased a 5 acre piece of land, i'm in Southern California.
The property has a well, the previous owner said the well is 200' and hasnt been used in a couple of years.
he said the pump died.
so i had an electrical engineer come by and we tested all the systems, they are all good. however, we decided to test the depth of the well also, we hit the bottom of the well at 180' and it was dry.
So i'm assuming that if the well was 200' there is 20' of sand or something else that has collapsed and filled up the well.
I've tried calling local well companies, but they're too busy with the big agricultural jobs, and the ones that were not said they're not interested in the job.
the well casing is 12" metal pipe, and the pipe going down to the pump is 2" metal pipe, so i have no way of getting the pump up, short of calling in a crane.. and even then if its under 20' of sand i'm sure it will just break off.
Is there anything that I can do?
Also, its worth noting that most of my neighbors also have wells and their are all good. never had any problems.
I havent had a chance to ask them of their depth though. But from talking to one of the well service companies, they said the water table is at 200~230' in that area.
Thanks!!
Thanks!!
