Deep Water Well Pump - 120v or 220 v?
Discussion in 'Pumps and Tanks Well Forum & Blog' started by chuck b, Apr 10, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Will be having a new water well drilled/installed for up north cottage in a couple of months. Have been on a shared well so new to wells. What are the pros and cons to installing 120v vs. 220 v submersible pumps?
    Also, what are details in well design should I consider, e.g. is there a way to drain line before winter between well and cottage (100' or so).
    Also, after the well line enters the cottage, can I "T" it off with the expansion tank one way, and the sediment filter the other way, or do I need to put them in a seperate order, i.e. expansion tank 1st, then sediment filter, then water softener, then hot water tank?
    Thanks.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I advise to go with a 220V system as they draw less amps. The only advantage of a 110V system is powering it with a cheaper genset.
    For drain-back, there are specialized systems available for cottages.
    http://www.cottagewatersupply.com/
    Most all tanks use a Tee of some sort. Some tanks may have a separate in and an out so the Tee is part of the tank. With the exception of a sand separator, in-line filers should always be placed after the tank.
  4. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    Although the 110 and 220 set-up use almost the exact same electricity I always advise to go 220, which seems to give more reliability in the long run.
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    I recommend that you use a 220 volt pump because amoung other advantages you can use smaller wire. I would also recommend that you install a Pside-Kick. With it you'll have a smaller tank, less pump cycling, constant pressure and less water to drain down in the winter.
    You can install a small valve below the pitless adapter (that can be opened by a long rod attached to the valve handle). When you want to winterize the system, cut off the power to the pump, drain the pressure in the system, open all the faucets, then remove the well cover (NOTE: Some states only allow a licensed drilling/pump contractor to do this.), open the small valve to allow the remaining water in the system to siphon back into the well. We did this in all hunting cabins in North Central Pennsylvania some 20 plus years ago.
    There should be nothing between the pump check valve on the pump and the outlet of the tank, such as filters and water conditioners.
Similar Threads: Deep Water
Pumps and Tanks Well Forum & Blog Deep well builds pressure but no water output Thursday at 5:11 PM
Pumps and Tanks Well Forum & Blog Muddy Water from deep well Dec 18, 2015
Pumps and Tanks Well Forum & Blog Deep water well completely clogged May 10, 2014
Pumps and Tanks Well Forum & Blog Water Level in Deep Well? Jun 30, 2013
Pumps and Tanks Well Forum & Blog Deep well jet pump low water pressure May 18, 2012
