Declining hot water output - how to fix ?
Discussion in 'Water Heater Forum, Tanks' started by Bob L, Jan 1, 2013.
  1. Bob L
    Bob L New Member
    Apr 11, 2012
    Metuchen NJ
    BACKGROUND: Over the past few months the hot water is running out more and more quickly, on my Rheem Guardian Fury 22V50F1 gas water heater installed in June 2007. For the first five years since installation, it would take about 30 minutes of continuous running of the upstairs shower bath for the hot water to exhaust, with water temperature set to 130 degrees. Starting a few months back the output of hot water has been declining, and is currently taking about 15 minutes to run out.
    QUESTION: Will appreciate advice on what to do. Will it be cheapest to replace the existing heater ? The warranty runs out in June 2013. Will the warranty cover this problem ?
  2. jadnashua
    Warranty is usually about leaking. If you have particularly hard water or are running on a well that is pumping up sand; the tank could be partly full of minerals or sand.
  4. Bob L
    Bob L New Member
    Apr 11, 2012
    Metuchen NJ
    Thanks for the advice on warranty. Our local water is not particularly hard. When I drained the tank, the first few seconds of water flow was a little bit gray in color, then it cleared up for the remainder of the drainage. 24 hours after refilling the tank it was still running out of hot water in about 15 minutes.
  5. akholbrook
    akholbrook New Member
    Dec 30, 2012
    NC
    I had this issue about a year ago but it was an electric water heater and it was a burnt out element. However since gas water heaters don't have elements check the burner on it. This maybe your issue.
  6. jadnashua
    Make sure nothing is drawing water, then go check out your water meter. If it is turning, you have a leak, and with the symptoms you're seeing, it's likely on the hot water side. A constant leak will keep a WH from maintaining much hot water with the constant introduction of cold water. Even a small leak can be an issue both for water/sewer expenses, and fuel to try to heat it.
  7. Bob L
    Bob L New Member
    Apr 11, 2012
    Metuchen NJ
    Thanks for the suggestion. I checked the water meter while all taps were off. The meter was not turning. Could the problem arise from [1] an attenuated flame [2] attenuated transfer of heat from the flame to the water in the tank ?
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Several years ago there was a problem with faulty dip tubes. One company made them and supply several brands of heaters. The tubes would break off which caused the incoming cold water to just go to the top of the tank. The result was very little hot water. This may not be your problem, because this was supposedly dealt with before your heater was built. I bring it up because the symptoms are very much like the broken dip tubes. Easy to check, it is right under the intake nipple and can be pulled out and replaced easily if it is broken.
  9. Bob L
    Bob L New Member
    Apr 11, 2012
    Metuchen NJ
    Thanks so much for the suggestion. The heater installation is crowded and I don't feel comfortable with removing the intake nipple as I strongly suspect I will create leaks and maybe other problems. I've now scheduled a highly rated (on ANgie's list) plumber to visit in 3 days time, and will tell him your idea, and will report back on what the actual solution (if any) was. Thanks again.
Similar Threads: Declining water
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Saturday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Water heating Feb 20, 2017
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Feb 20, 2017
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
