Debris in my filter housing - what is it?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mortal798, Jul 22, 2013.
  1. mortal798
    mortal798 New Member
    May 9, 2011
    Pinckney, MI
    I have a bunch of 'stuff' showing up in my filter housing. I'm not sure what it is. I don't know if it is being pulled up out of my well, or if the inside of my pressure tank is rusting and falling apart. I will post some pictures in a minute...
  2. mortal798
    May 9, 2011
    Pinckney, MI
    Here are 2 pics: debris 1.jpg debris 2.jpg
  4. mortal798
    May 9, 2011
    Pinckney, MI
    Any ideas?
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    What kind of tank do you have?
  6. mortal798
    May 9, 2011
    Pinckney, MI
  7. craigpump
    Apr 12, 2012
    It's possible the diaphram has ruptured and the shell is rusting from the inside out. How old is the tank?
    Does the tank feel heavy?
    If you knock on the lower 1/3 of the tank when it's empty does it sound hollow or is there a dull thud?
    Does the pump short cycle?
    If you run a hose off the tank does the water run clear?
    What is the air pressure on the snifter valve at the top of the tank when the tank is empty?
    Do you get any water out of the snifter valve when the tank is up to pressure?
  8. mortal798
    May 9, 2011
    Pinckney, MI
    The tank is original to the house as far as I know - 1994.
    I will empty it today and find out what it sounds like, how heavy it is, as well as what the air pressure is.
    The pump does not short cycle, I replaced that 2 years ago.
    I will check the water clarity when I empty it.
    What is the snifter valve? Do you mean the Schrader valve like on a tire - for filling it with air?
  9. mortal798
    May 9, 2011
    Pinckney, MI
    Thanks, by the way, for your help. I really appreciate it!
  10. BenWoj
    BenWoj New Member
    Aug 19, 2013
    Tecumseh, mi
    Glad you posted this. I have the same issue and assumed it was coming from the well. I'll have to check my tank now.
Similar Threads: Debris filter
Pumps and Tanks Well Forum & Blog. Water is life. Debris coming from Well Dec 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Having unknown well problems: debris Jun 22, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water Filter Design Oct 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well to pressure tank to whole house filter to Jun 26, 2016
