Danco Replacement 80993 Question
Discussion in 'Shower & Bathtub Forum & Blog' started by Blueprint99, Aug 3, 2010.
  1. Blueprint99
    Blueprint99 New Member
    Aug 3, 2010
    MA
    Hello, I just installed this Danco replacement single handle faucet on my mother's Moen Shower.
    [​IMG]
    Everything works fine but it's noticeably louder than the original piece(like a ton of water is rushing through), especially when adjusting the temperature(the flow seems to stutter between hot and cold). Also, whenever the water is turned on and off the pipes knock a bit. I followed the instructions properly and am curious what's wrong? I'm assuming this aftermarket unit is junk... TIA!
  2. jadnashua
    There have been several threads recently, and the concensus is, use OEM parts, the Danco may not leak, but clunks...Depending on the age, Moen may have a lifetime warranty on that part, and you can get it from them. WOrth a call.
  4. hj
    If that is the stem you used, it does not have a pressure balancing spool in it, although there could be one if the valve if it is a MoenTrol version.
  5. txchad
    txchad New Member
    Dec 21, 2009
    Texas
    There's also a plastic / brass version of that stem that is interchangeable with this one. You might try that one.
Similar Threads: Danco Replacement
Shower & Bathtub Forum & Blog Danco 80959, old shower valve Jan 1, 2017
Shower & Bathtub Forum & Blog Danco diverter stem problem Dec 7, 2010
Shower & Bathtub Forum & Blog Water Hammer knock - DANCO? Oct 28, 2009
Shower & Bathtub Forum & Blog Extremely Tight Danco Stems - How to? May 21, 2006
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
