cycling of pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rreith, Sep 23, 2013.
  1. rreith
    rreith New Member
    Sep 22, 2013
    michigan
    I sure you nice folks can help. A couple of day ago I noticed that my well pump started cycling a lot, so I looked at the pressure-it would drop to about 40psi and kick on the pump. pressure would come up quickly-within a few seconds, then shut off at about 70psi then drop back down to about 40 within about a minute. I suspected a leak so I shut off the valve after the tank and still the drop in pressure. I have determined that I losing pressure on the pump side. doing some reading I have assumed it is some sort of check valve or sifter valve. im not sure where these are located to check them. I have a red jacket 1/2hp submersed pump. thank-you very much for the help.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the pressure comes up within seconds, your tank is probably waterlogged. Do you have a bladder tank?
    The pressure loss could be a bad checkvalve or a leak between the pump and the tank.
  4. rreith
    rreith New Member
    Sep 22, 2013
    michigan
    I do have a bladder type tank. I assume it has kind of an air bag inside it. it has a vale stem on top of the tank. can I or should I check for water in there? How do I check for leak in between pump and tank. my pump is out in the back yard and tank is in basement. thanks so much for your help!
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    In that case, the leak might be at the footvalve.
    Earlier you said you had a submersible. SO which is it, in the back yard or in the well?
  6. rreith
    rreith New Member
    Sep 22, 2013
    michigan
    My pump is a submersible in a well in the back yard. thanks.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Ok, then split the system at the pitless. Lift the pump so you can cap the line with a Tee that has a pressure gauge and a schrader valve. Pump air in and see if it holds. If it doesn't hold, the leak is between the pitless and the pump. If it doesn't leak suspect a leak between the pitless and the tank.
  8. rreith
    rreith New Member
    Sep 22, 2013
    michigan
    Thanks- appreciate your time. Ill give it a shot.
  9. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You need to drain your tank to make sure the tank has the proper amount of air in it.
    If your tank is waterlogged a leaking valve will seem to be a big problem, But you can live with a small leak short term if needed, If your tank has air in it. But the pump will cycle every now and then when no water is in use.
    Good Luck.
Similar Threads: cycling pump
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Pressure Switch constantly cycling on and off Mar 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
