Cycle Stop Valve
Discussion in 'Irrigation / Sprinkler Forum' started by 11thacr, Nov 2, 2007.
  1. 11thacr
    11thacr New Member
    Oct 12, 2007
    I have a sub pump with a Square-D Switch and a Bladder Tank hooked up to a shallow well and I'm using for irrigation only. Everything is working just fine except the Sprinkler heads are having a hard time shutting down. I was assuming it was because of the difference in pressure. My switch is cut on at 40 and off at 60 with the bladder Tank set at 38. The pressure is fine and also the volume. I was wondering if a CSV would help my situation. and by the way I have a pumptec also connected.
  2. aceto
    aceto New Member
    Mar 6, 2005
    new york
    from another posting I was told that pumptecs will not work properly with csv's.
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Lawn sprinklers that aren't shutting down would be most likely caused by the zone valve(s) - for a start, you want valves with flow controls, and to have those flow controls throttled down, as that greatly improves valve closing.
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    A Pumptec works by sensing the lower current to the pump when the water drops in the well. When the current is too low, below the normal current, it shuts off the pump until some time has elapsed so the well can recover.
    A CSV reduces the flow from the pump to about 1 GPM. Reducing the flow also reduces the current to the pump.
    If the current at 1 GPM is less than the "low-current" setting on the Pumptec, then the Pumptec will shut down the pump.
  6. 11thacr
    11thacr New Member
    Oct 12, 2007
    Tried wet_boots idea and that fixed the problem. Thanks Bob NH for the info on the pumptec. Everything is working fine.
Similar Threads: Cycle Stop
Irrigation / Sprinkler Forum Shallow Well Lawn Irragation pump cycle problem Mar 12, 2011
Irrigation / Sprinkler Forum Lawn Sprinkler Pump Short Cycle Jul 20, 2010
Irrigation / Sprinkler Forum Connecting one valve to two stations to get more cycle times Jul 2, 2009
Irrigation / Sprinkler Forum Heads "ooze" water after cycle ends Jun 13, 2007
Irrigation / Sprinkler Forum Pump cycles too much Mar 29, 2007
