cutting vertical cast iron stack...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by coach606, Jul 2, 2006.
  1. coach606
    coach606 New Member
    Apr 25, 2006
    Illinois
    Just planning here. I will eventually run a 3" drain line to a vertical cast iron stack in the basement. The basement stack has cast iron plumbing above it for a bathroom and the goes through the roof. This plumbing is well supported, but I plan on providing more support before cutting the stack.
    After making sure there is tons of support for any pipes above, I'm going to build a soffit around the C.I. stack and attach riser clamps to it above an below the cut.
    I'll then cut a section of pipe out using snap cutters. My plan is to use a no hub wye fitting 3 x 3 x 3 and fit it into a street 45 to head vertical and pick up the dwv. Or is it better to just use a 3 x 3 x 3 pvc fitting with two no hub adapters?
    Any problems with doing it this way? I know things can go wrong, but I assume that if I properly support all the pipes I can use a no hub fitting to connect pvc to my cast iron.
    Or do I need to consider getting a cast iron wye fitting, pounding in oakum and then sealing over it with liquid lead?
    thanks for the advice.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Use banded couplings.
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    If I had nothing better to do, I might try this...just to see what it is like. Completely unecssary though.
    If noise is an issue, I would do hubless CI or PVC if it is not.
    Jason
  5. coach606
    coach606 New Member
    Apr 25, 2006
    Illinois
    noise isn't an issue...
    Noise isn't an issue so I guess I'll just go with the pvc and banded couplers.
    Can anyone explain the hubless cast iron? I'm not sure I understand how it works, unless it just sits on the hub of two banded couplings.
  6. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    A fun job, especially making the molten lead run uphill to seal the lower bell on the wye fitting.
  7. Lakee911
    Aug 23, 2005
    Columbus, OH
    The stainless steel banded rubber/neoprene/whatever couplers are the essentially a two-ended hub. You insert both pieces of pipe into the connector/coupler. (They are just butted up together--one pipe does not enter into the other). After you crank down on the bands, it pulls it alltogether inline and forms a leakproof rigid connection.
    Jason
  8. Lakee911
    Aug 23, 2005
    Columbus, OH
    How do you do that?
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Ask an old plumber, I guess. I remember watching my father when we built our house back in ought-50, but I don't remember the details. As I recall, there was a rope-like thing wrapped around the lower pipe that allowed you to pour a ring of lead in the general area, then it was tamped upward with a kind of offset chisel-thingy called a caulking iron or packing iron. All the lead does is hold the oakum in place, so it doesn't have to be pretty -- just tight.
  10. Bud1300
    Bud1300 Plumbing Contractor
    Jul 3, 2006
    Plumbing Contractor
    Wetumpka Alabama
    You install 1 inch of okum and pack it with a packing iron then you install a joint runner and pour your lead then you us a inside caulking iron then a outside caulking iron to complete the job.
  11. Lakee911
    Aug 23, 2005
    Columbus, OH
    Ahh I see. Ok. Thanks.
Similar Threads: cutting vertical
Plumbing Forum, Professional & DIY Advice Lady needs advice on cutting ballcock stem Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Risk of cutting galvanized where it enters the crawl space May 11, 2016
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
Plumbing Forum, Professional & DIY Advice Cutting PVC pipe...angle? Sep 11, 2014
