Cutting through a 2" brass valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by jeffeverde, Mar 29, 2013.
  1. jeffeverde
    jeffeverde New Member
    79
    L.A.
    My pool is plumbed in 2" copper. After 40 years, all but one of the brass gate valves has stripped it's stem, and of course, the manufacturer has gone out of business and I can't find a match to swap parts with.
    I've got four valves side by side, feeding into a manifold, and I'd like to leave the manifold intact. There's a union at the other end of the manifold, so my thought is to pull the innards from all the valves and cut the valve bodies in half with a sawzall (the valves are spaced too close together to get to the middle valves with a grinder). Then I can sweat off the valves one at a time, rather than trying to torch four 2" valves all at once. (and yes, I've got mapps and acetylene torches)
    Has anyone sawzall'd a brass valve? Is the alloy soft enough to cut with a bimetal blade? I might be able to get to the outside valves with a grinder, but I definitely don't have clearance to reach the middle pair.
    Or am I missing something and there's a better way to skin this cat?
  2. BobL43
    BobL43 DIY Senior Member
    1,786
    Long Island, NY
    Jeff, first of all, I am not a plumber, but I do have a sawzall:p. I have used the saw to cut through 2 inch galvanized pipe, and I would imagine that a brass valve should cut like butter with a regular fine tooth metal cutting blade. I would like to hear what the pros say on this too.
  3. hj
    26,304
    Cut the valves through the ends just past the end of the pipe going into it. Almost any metal cutting blade will cut the brass. As a side issue, using copper for a swimming pool, I assume it is a swimming pool, usually results in "green" stains around the openings and deterioration/erosion of the copper tubing.
  4. jeffeverde
    79
    L.A.
    41 years and not a stain (my parent's house). Now if only my dad had done periodic maintenance on the valves :p
    Thanks for the advice. I was pondering changing the above-ground plumbing to PVC. But then I figured - "the first set of valves lasted almost 40 years - why mess with a good thing".
  5. hj
    26,304
    There is probably NO periodic maintenance which would have "saved" the valves. The problem is the composition of the brass and the chemicals in the water. "Better" valves might have been a better option, but pool builders are not known for using "quality" materials when a cheaper one works just as good.
Similar Threads: Cutting through
Plumbing Forum, Professional & DIY Advice, Tips & Cutting concrete around basement shower drain? Best way? Jun 9, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Cutting PVC Pipe Jul 2, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Cutting concrete floor containing PEX radiant heat lines Apr 28, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Cutting Cast Iron Y! Mar 17, 2012
Plumbing Forum, Professional & DIY Advice, Tips & Cutting Black Iron Pipe Nov 8, 2011
