Cutting PVC Pipe
Mario the Plumber
Tennessee
Except for being a bit slow, is there anything wrong with cutting small PVC pipe with a wheeled cutter intended for copper tubing? The wheeled cutter seems to produce excellent results, while ratcheting cutters don't make square cuts.
JohnjH2o1
Florida
You can use a cutter but a copper cutter wheel it will leave a burr on the outside of the pipe. There is a cutter wheel just for plastic pipe.
John
The blade is not large enough to cut through the thick wall, usually. Normally you need a large wheel with a thin blade. It is up to YOU to set the ratcheting cutter so it cuts square.
As noted, a typical tubing cutter won't cut all the way through on most pvc drain pipe. What it will do is give you a cut most of the way through that is pretty square to the length, then a few strokes with something like a hack saw will finish it off. With practice, you can get a good cut with a sawsall lots faster.
