Cutting PVC pipe - need to get it straight
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rrzepka, May 9, 2005.
  1. rrzepka
    rrzepka New Member
    Dec 11, 2004
    What is the best way to get a clean, straight cut in PVC pipe? My task is to cut out the appropriate length in order to splice in a 3" x 3" 1.5" tee connection. When I've tried to cut PVC pipe in the past, I'm always a bit off from a true, straight cut.
    The pipe in question is 3" in diameter, its located in an unfinished portion of my condominium and is slightly above eye level. Should I use a cabled saw, a PVC pipe saw or some other device? What should I do to ensure a straight cut?
    -Robert
  2. Bob's HandyGuy
    Bob's HandyGuy Senior Member
    Sep 10, 2004
    They have a tool made for cutting PVC. I never bought one since I don't do a lot of plumbing work. I just use my power miter saw. It gives a nice, straight cut if you ease the blade down slowly.
  4. George R
    George R New Member
    Mar 7, 2005
    Central Illinois
    Straight cut
    Take a piece of paper and tape it around the pipe, lining up the edges of the paper at the point where you want to make the cut. Trace the line of the paper onto the pipe with a sharpie. Remove the paper and then cut with a sawzall or a cable saw, depending on the access.
  5. Dave Meers
    Dave Meers New Member
    Jan 29, 2005
    When making a cut with the PVC pipe in place, I put a metal hose clamp around the pipe (like a car radiator hose clamp) and use it as my straight edge. It helps make for a nice cut. :)
  6. rrzepka
    rrzepka New Member
    Dec 11, 2004
    Many thanks to George R and Dave Meers for excellent suggestions.
    -Robert
  7. hj
    cut
    Do not expect to get a straight cut if you use a cable saw.
  8. Pewterpower
    Pewterpower New Member
    Jun 25, 2006
    sales
    Tampa
    I've used this garden tool lots of times. I think it's called a pruner, but I trim/cut branches and stuff with it. It works great on pvc, conduit, etc...
    [​IMG]
  9. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I'd like to see a video of you cutting 3" PVC pipe with a garden pruner. That would be pretty funny.:D
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Maybe he has really big bushes and trees. Fortunately, the cut on PVC does not have to be to the nth degree of straight. Close will be just fine. The paper and hose clamps are good, also masking tape. Cutting 3" or 4" pipe in place can be a bit tricky. If you have really good access, a jig saw with a fine blade works pretty good. A cable saw will cut it, but is hard to keep straight. If the pipe is not attached, I find my band saw will give me a good straight cut.
  11. Cass
    Cass Plumber
    Nov 12, 2005
    A sawsall with a long 24 TPI blade will make a straight enough cut for you.
  12. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    I use a 12" miter saw for anything over 1". Produces a nice clean cut, but you've got to be sure to hold the pipe securely to prevent it from spinning. Haven't found a PVC pipe cutter yet that will produce a true square cut. I like the idea of using the lopper -- I'll give it a try.
  13. Pewterpower
    Jun 25, 2006
    sales
    Tampa
    No, of course not 3" :D
    But I've used it on some pretty good size conduit.
    That's what I get for steering slightly off-topic.... :p
  14. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    LOPPER?: But I've used it on some pretty good size conduit.
    Conduit is not as brittle as water pipe. I would be concerned about cracking the water pipe.
  15. Pewterpower
    Jun 25, 2006
    sales
    Tampa
    Ya, it definately needs to be real sharp. Mine probably is not anymore, since I use it mainly on my mutant bougainvilleas from hell. I've cut branches 1.5" thick with this thing.
    I got the idea at the hardware store where I saw one of the employees use the handtool cutter on some pvc. It went thru it like butter. So the next time I had to cut some pipe, I used my pruner/cutter/trimmer/lopper whatever the hell you call it!!! and it worked like a champ.
    But you're right about cpvc. You could easily crush it, if you're not careful.
    The bigger pipes, a mitre saw works great. A hacksaw is the WORST.
  16. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    For about $8 you can buy a real pvc pipe cutter that will do a real good job.
    But I'll be darned as to why you you don't just use a hacksaw blade.
  17. molo
    molo Member
    Sep 23, 2006
    Cold New York
    Confused
    Whats wrong with a hacksaw compared to garden shears to cut pvc? I am laughing, (but not too loud, because i have never tryed garden shears). Are they really easier than a hacksaw?
  18. jadnashua
    WIth the right shears, it is about as fast as you can squeeze the handles...makes a nice, clean, burr-free cut. I've got a pair for up to 1.5", and it works great. Didn't cost me much, either. I've seen them for larger pipe, but haven't used one.
  19. Pewterpower
    Jun 25, 2006
    sales
    Tampa
    Hacksaw blades are too flimsy and have too much play. If you are cutting a large pipe, that blade will be all over the place.
  20. Lancaster
    Lancaster New Member
    Nov 7, 2005
    One guy I know (and only one) has a Ridgid tubing cutter with a special plastic-cutting wheel (as opposed to the copper cutting wheel).But it should be noted that he is for all purposes retired and does very little plumbing anymore.It does give a nice clean cut but I am sure its time consuming.Works for up to 2" PVC.
  21. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I use a cordless navigator and it makes little work of cutting even 6" PVC piping.
    Been using it for two years and works great. [​IMG]
Similar Threads: Cutting pipe
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
Plumbing Forum, Professional & DIY Advice Cutting PVC pipe...angle? Sep 11, 2014
Plumbing Forum, Professional & DIY Advice Cutting PVC Pipe Jul 2, 2013
Plumbing Forum, Professional & DIY Advice Cutting Black Iron Pipe Nov 8, 2011
