cutting pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jvl, Jan 1, 2008.
  1. jvl
    jvl New Member
    Dec 9, 2007
    California
    hello,i am having a problem cutting the galvanized drain pipe under a house.using a reciprocating saw and laying on my back ,i seem to have a problem of cutting it straight.is there a secret or a guide that i should know about.thanks jvl
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Keep the shoe of sawzall flat against the pipe.Start out slow untill cut to
    inside of pipe.SAFTY GLASSES!
  4. JeffH
    JeffH New Member
    May 21, 2006
    California
    Take your time...
    #1 - Wear safety glasses
    #2 - Practice on scrap pieces.
    #3 - Use the right size/type blade for the job.
    #4 - The shoe is meant to be a guide for leveling and stability. Hold the shoe tight to the pipe. Lock your arm against your body for stability. When you start to cut while keeping the shoe against the pipe, let the tool do the work. Eventually, you'll get a feel for when to apply more/less pressure. Just like welding/soldering it's always good to practice on scrap pieces to build confidence.
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Put a lenox gold blade in that saw!
  6. jimbo
    jimbo Plumber
    Galvanized is not so hard to cut. Use a new metal cutting blade. Are you sure it's not cast iron? That's different!
  7. Redwood
    Dec 15, 2007
    Service Plumber
    The lennox gold will do the cast iron too... Recently I used the same blade
    1 1/2 days on a job cutting cast and galv.
  8. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Try a Milwaukee "Torch" blade.
    Lennox is the name I usually get for hole saws and blades, but the Torch's are fantastic.
  9. hj
    cut
    wrap a paper strip around the pipe and mark a straight line. The cut to the line.
Similar Threads: cutting pipe
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
Plumbing Forum, Professional & DIY Advice Cutting PVC pipe...angle? Sep 11, 2014
Plumbing Forum, Professional & DIY Advice Cutting PVC Pipe Jul 2, 2013
Plumbing Forum, Professional & DIY Advice Cutting Black Iron Pipe Nov 8, 2011
