Cutting drain pipe for new shower
Discussion in 'Shower & Bathtub Forum & Blog' started by fozzy12, Jan 5, 2009.
  1. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    North of Detroit, MI
    When I had my house built, I had a plumber rough in the underfloor drains for a basement bathroom including a sewage crock. He left the pipes sticking out of the floor and capped. Now, I'm finishing the bathroom. The shower will be ceramic tile with a mud bed. I cut around the drain pipe in the shower with a diamond saw because the pipe is sticking up to far. I got the area around the pipe excavated down to where it needs to be. What method do the pros use to cut the pipe off below the floor so it's square? There isn't a lot of room in the hole, I only cut out a 6" square of concrete around the pipe.
    Any help would be appreciated.
    Eric
  2. jadnashua
    They make inside pipe cutters, but they still take a little skill to get it nice and even...
    For tiling help with the shower, check out www.johnbridge.com. If you haven't looked at it, consider using Kerdi from www.schluter.com. Personally, I really like the way that stuff performs and put in one for my mother using it.
  4. fozzy12
    fozzy12 New Member
    Jan 31, 2008
    quality manager
    cutting drain pipe
    Jim,
    Thanks for the reply. I didn't know they made inside pipe cutters. That would be the ticket if you had one. I have looked at Kerdi systems and they look really nice. I'm using hardie backer cement board for tile backer and I have looked at John Bridge.com. They have lots of good info out there. I wish there was a way for me to use the whole kerdi system but on this particular job, my drain is not in the center of the floor and the shower is odd sized, so I'm going the old fashioned way.
    Eric
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Inside Pipecutter...
    stuff a rag in the pipe to catch it if it falls out of the drill.
    If you don't I guarantee it will fall out and go bouncing down the drain pipe where you can't get it!
    [​IMG]
  6. jadnashua
    Kerdi can be installed equally well on a mudbed as it can on their preformed pans. One beauty of this is that you only need to do one layer, rather than two for a conventional shower. You just install the Kerdi to what would be the pre-slope of a conventional pan but you must have already installed the Kerdi drain.
Similar Threads: Cutting drain
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog Cutting a cultured marble sink bowl out? Dec 31, 2014
Shower & Bathtub Forum & Blog Is this diamond cutting blade installed correctly? yes or no Dec 5, 2014
Shower & Bathtub Forum & Blog Cutting flange on alcove tub? Anyone done this before? Feb 13, 2014
Shower & Bathtub Forum & Blog Is methane dangerous when cutting cast iron? Jan 12, 2009
