Cutting Cultured Marble?
Discussion in 'Shower & Bathtub Forum & Blog' started by Elton, Sep 11, 2005.
  1. Elton
    Elton Electrician
    Sep 11, 2005
    Electrician
    Minnesota
    I am going to install cultured marble panels on my tub walls. I understand the panels can be sawn with a masonry blade, but can carbide saw blades be used also. I would appreciate any advice.
    Thank you.
    Elton
    http://www.veronashowers.com/master-bath-pictures
  2. hj
    blade
    I have never tried a masonry blade, but I suspect it would "burn" or melt its way through the marble. I use a convention, fine tooth blade, to minimize chipping and cut from the back side.
  4. Elton
    Elton Electrician
    Sep 11, 2005
    Electrician
    Minnesota
    Thank you
    I appreciate your reply. I had been planing to cut it with a fine tooth carbide blade but I had been reading that people were using masonry blades. I didn't think that would be as good as using the carbide. I like your tip about cutting from the back side to minimize the chipping.
    Thank you.
    Elton
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    jig saw
    cutting it with a jig saw has
    worked pretty well for me in the past
    less stress on the marble and less dust
    I never cared for "ripping through " the stuff
    slower seemed to be more my speed
    just take some duct tape and make a tape line along where you
    want to cut to so niether the poower saw or the
    jig saw sctarches the marble.
Similar Threads: Cutting Cultured
Shower & Bathtub Forum & Blog Cutting a cultured marble sink bowl out? Dec 31, 2014
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Tuesday at 6:47 AM
Shower & Bathtub Forum & Blog Is this diamond cutting blade installed correctly? yes or no Dec 5, 2014
Shower & Bathtub Forum & Blog Cutting flange on alcove tub? Anyone done this before? Feb 13, 2014
Shower & Bathtub Forum & Blog Is methane dangerous when cutting cast iron? Jan 12, 2009
