Cutting ABS Straight??
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Geo, Jun 21, 2007.
  1. Geo
    Geo New Member
    Jul 9, 2006
    This weekend I am going to cut out a section of 3 inch underground ABS out of a hole I cut under my slab to insert a Wye.
    My question is is there any easy way to make sure I get a straight cut? If I don't get it 100% straight I don;t think the banded no-hubs I have will seal correctly since they seem to want a 1/4 inch gap
    Any easy way to make sure the cut is straight? Maybe use raditator clamps?
    Thanks!!!
  2. Cass
    Cass Plumber
    Nov 12, 2005
    That ill work
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Hand-eye coordination.
  5. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Personally when I am unsure, I break out my plutonium Q-39 space modulator for that.
    (that was grumpy humor)
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Huh................using old tools instead of the newest model.........that thingie has to be 50 years old.
  7. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Hose clamps are bad for your teeth. Cut a couple of feet of 1x4 into three pieces with square ends, then nail then together like a trough to slip/flare down over the pipe and serve as a guide for your sharp handsaw.
  8. HandyAndy
    HandyAndy General Contractor, Farmer
    Apr 17, 2007
    Haxtun, CO
    take a piece of paper and wrap around the pipe and then mark a line on it, the paper edges can be lined up and it will be square, (or at lest the mark you make on it will be), then use the line as a guide to cut it,
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    well...30 anyway
  10. HandyAndy
    Apr 17, 2007
    Haxtun, CO
    I have never tried this trick but it does make some sense,
    I saw it on an electrical board,
    I would think if it would work on PVC it would work on ABS as well, If you try it report back and tell us how it works?
    or
  11. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Guitar string or cable cutter. but, it's not as easy as a hacksaw...best bet is a PVC saw or...if yer skilled...sawzall with a metal blade, good eye and STEADY hand.
  12. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I thought that the only redeeming feature of PVC/ABS is that your cuts don't have to be perfect--just close. I've never had one leak yet and my cuts are definitely not perfect.
  13. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I've used string to cut pvc in the ground. Makes for a much smaller hole to dig.
  14. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    A few hints about wire saws and the like...
    1 - you can buy one for a couple bucks at HD etc.... - string only works marginally...
    2 - don't try it if there is any standing water in the pipe... soon as the string/wire breaks through, the water flows into the cut and welds the melting PVC/ABS to your wire and you are done...
    3 - be very careful how you cut as the wire can and will travel in curves - it takes a knack to cut it straight....
    That being said, the wire saw is a great tool for cutting plastics in tight places... but I tend to use a sawsall with an 18 tpi metal-cutting blade for smoother more controlled cuts...
Similar Threads: Cutting Straight
Plumbing Forum, Professional & DIY Advice Cutting PVC pipe - need to get it straight May 9, 2005
Plumbing Forum, Professional & DIY Advice Lady needs advice on cutting ballcock stem Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Risk of cutting galvanized where it enters the crawl space May 11, 2016
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
