cutting abs 2 inch drain in tight quarters?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pmaru77, Nov 1, 2008.
  1. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
    Is there a special tool to cut plastic piping in tight spaces? I have a shower drain that split and have to get in there and splice some new piping.
  2. hj
    pipe
    What kind of pipe? White PVC or black ABS?
  4. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
    It's 2" ABS drain pipe. I just bought a wire thing to cut it. It got about 1/3 the way and now is stuck.
  5. jadnashua
    Timing is everthing. The wire cuts through heat caused by friction (it actually melts through if it's the kind I think it is). If you stop part way through or go too fast, it get get liquid and seal up behind or on the wire.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I only use the wire on pvc...
    Try a regular saw...
  7. pmaru77
    pmaru77 Member
    Nov 1, 2008
    Mech Eng/designer
    California
    yeah......I fugured...but too late. Well...it's cut out. I bought 2 45 deg elb. because that is what I thought I cut out, but further inspection...the elbow (orig) are 30 deg. There is only a 6 inch shift (offset) needed and I'm guessing that the 30's make it a little easier to line up, along with draining better.
Similar Threads: cutting inch
Plumbing Forum, Professional & DIY Advice Cutting 2 inch and 3 inch copper pipe Nov 9, 2006
Plumbing Forum, Professional & DIY Advice Lady needs advice on cutting ballcock stem Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Risk of cutting galvanized where it enters the crawl space May 11, 2016
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
