Cutting 2 inch and 3 inch copper pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JohnO, Nov 9, 2006.
  1. JohnO
    JohnO New Member
    Nov 4, 2006
    New York
    Is there a good tool out there to do the job? I would rather not use a hacksaw or a dremmel. The only tubing cutters I can find only go up to 1inch and I think an 1/8.
    The two inch copper pipe if for a shower so it must be right on.
    Thanks.
  2. hj
    cutter
    There are many cutters that will cut up to 2", and they are expensive. For 3" you need an even larger, and more expensive one, but it will also cut 2". Draw a line around the pipe and use a hacksaw, not the Dremel tool.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    After cutting as HJ advises, use a round file on the inside to clean up the resulting jagged edges and a flat file on the outside. Remember, while you want the ends to have a reasonably straight cut, the ends go inside of a fitting, will never be seen, so a slight imperfection in the cut really won't matter. You just don't want any sharp edges on the inside or outside of the pipe.
Similar Threads: Cutting inch
Plumbing Forum, Professional & DIY Advice cutting abs 2 inch drain in tight quarters? Nov 1, 2008
Plumbing Forum, Professional & DIY Advice Lady needs advice on cutting ballcock stem Nov 27, 2016
Plumbing Forum, Professional & DIY Advice Risk of cutting galvanized where it enters the crawl space May 11, 2016
Plumbing Forum, Professional & DIY Advice Cutting into a pipe to add a fitting: a tight spot Dec 22, 2015
Plumbing Forum, Professional & DIY Advice Cutting drywall for repipe Dec 9, 2015
