Cut out drain?
Discussion in 'Shower & Bathtub Forum & Blog' started by wbrisett, Mar 10, 2009.
  1. wbrisett
    wbrisett New Member
    Mar 10, 2009
    Our house was built 22 years ago, we've been here 10 years now. Recently it became evident that we needed to replace the fixtures in one of the bathrooms. All went well until I got to the drain. When I tried to unscrew it, I ended up breaking the crossbars at the bottom of the drain. So now it looks like I'll have to cut it out. The question is what is the best way to do that? The unit simply won't budge, every time I grab a corner with vise-grips, the corner simply comes off. So, off it comes, but I really don't want to damage the tub any more than it is (some of the fiberglass has already chipped off, I'll have to see about finding a refinishing kit when I'm done with the drain).
    I see recommendations to cut out drains in this forum quite a bit, but no suggestions on what tools or how to actually do that.
  2. jimbo
    jimbo Plumber
  4. hj
    drain
    I wouldn't want to tell you how or what to use, especially with a fiberglass tub because you could damage the tub to the point where it would have to be replaced. Bite the bullet and call a plumber who has the correct tools to do it, and the experience.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
Similar Threads: drain
Shower & Bathtub Forum & Blog Delta Acrylic Bathtub Drain Sealant Tuesday at 11:03 AM
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
