jpaul
I have a well-rite (wr 120r) bladder tank with a 40/60 square D switch and submersible pump an a pumptec. The cut in is 40lbs and cut out 44lbs.
The air pressure was 25lbs and I increased it to 38lbs but it did not make a difference.
I started looking at everything because of lower water pressure. Pressure seem pretty good now.
Could you offer some suggestions of where to go from here regarding the switch range?
pump and pumptec are 10 years old the pump is down 300', tank is 16 years old. I have iron in water.
There is also a 5 micron sediment filter after the tank that I change weekly because of orange film. Changed today and already orange.
Thank you!
Thank you!
