Culligan MK 50 programming settings
Discussion in 'Water Softener Forum, Questions and Answers' started by Outhouse, Aug 8, 2010.
  1. Outhouse
    Outhouse New Member
    Aug 8, 2010
    Chesapeake, VA
    I've had a Culligan MK 50 for 6 years and after the original company installation, the settings just don't seem proper. There are 3 adults in the home and occasionally the toilet water is brown and the water has an iron smell. There's no bridging in the salt tank, but have noticed it uses less salt when I switched to a higher quality salt with "red out" (is this dreaming, or could it be?)
    I just today changed the settings to:SLEP 15, BUU 25, BR 60, CAP 31 and am currently regenerating. The new settings are higher than previously set.
    Am I in the Outhouse with these settings?
    I would appreciate suggested settings for this unit based on the above information. Thanks!
  2. Bob999
    Bob999 In the Trades
    Jul 4, 2009
    Pennsylvania
    To properly set up your unit you need to provide a water analysis that includes, at a minimum, hardness, iron, manganese, pH, and TDS.
    Your water quality could have changed over 6 years or the unit may not be functioning properly. Changing the salt will not change the amount of salt used--but a malfunctioning unit can use less salt and not provide adequate softening.
  4. Outhouse
    Outhouse New Member
    Aug 8, 2010
    Chesapeake, VA
    Thanks for the reply, I'll get a water sample tested and post results for comments from the experts here.
Similar Threads: Culligan programming
Water Softener Forum, Questions and Answers Culligan Installation/programming manual Apr 29, 2014
Water Softener Forum, Questions and Answers culligan programming questions Sep 26, 2013
Water Softener Forum, Questions and Answers Culligan MK 50 programming settings - missing a step? Time for a change? Sep 26, 2010
Water Softener Forum, Questions and Answers Culligan Mark 89 always draining Jan 7, 2017
Water Softener Forum, Questions and Answers Replacing Culligan Super S Jul 12, 2016
