Culligan Gold series softener has constant overflow
Discussion in 'Water Softener Forum, Questions and Answers' started by kerby, Oct 14, 2010.
  1. kerby
    kerby New Member
    Oct 14, 2010
    Washington
    We inherited a 12inch gold series softener and it has worked fine for months but now it is constantly overflowing into the drain. The only thing which stops it is turning on the outside irrigation.
    Can anyone help? Thanks!
  2. Skip Wolverton
    Skip Wolverton In the Trades
    Dec 27, 2009
    Owner of SWS Systems. I work on most water treatme
    Ocala, Fl
    If it runs to the drain, the seals are bad. http://www.culligan.com/en/service-and-maintenance/customer-support/owners-guide/obsolete-manuals/ Try this site and find the manual for your unit. You may need to replace the piston as well as the seals and spacers.
  4. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    When you say that it is over flowing to the drain, is that the main valve or the brine tank?
    If it is the main valve then either the main piston and seal assembly has a seal out of place , the piston has a grove are the only two real items that will have the unit dumping water to the drain when the unit is in service.
    If it is over flowing the brine tank then there is a plug in the injector assembly area, most likely the injector and screen are pluged.
    Culligan is looking for 150.00 at least for the rebuild kit that has the main piston with seal pack and the brine piston with its cage.
Similar Threads: Culligan Gold
Water Softener Forum, Questions and Answers Culligan Gold series softener keeps regenerating Dec 13, 2013
Water Softener Forum, Questions and Answers Help with Culligan Gold Series Metered 9" WS float Feb 14, 2013
Water Softener Forum, Questions and Answers Culligan Gold/Silver Regenerating daily Apr 19, 2012
Water Softener Forum, Questions and Answers Kinetico Sulfur Guard vs. Culligan Iron-Cleer/Gold Softner Aug 20, 2009
Water Softener Forum, Questions and Answers Culligan Medalist Series Model WG844 Tuesday at 7:12 AM
