Culligan Estate 2 not working automatically
Discussion in 'Water Softener Forum, Questions and Answers' started by mrk431, Jan 5, 2013.
  1. mrk431
    mrk431 New Member
    Jan 5, 2013
    Minneapolis
    I have a 12 year old Culligan Estate 2 water softener. When I do a manual regeneration it seems to work fine. If I do that every day, I get soft water. It does not work automatically. I have not changed any settings. The clock is running and the linkages appear to be OK. I did notice that the lever that is supposed to start a regen does not move as far when tripped by the wheel from the clock as when tripped by hand. Can anyone help?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Is yours on the 6 day or on a meter?
    any chance of a photo?
    If the pins are all out then the unit will not trip into a cycle.
    If the meter cable is not all the way in at either the meter dome or the timer assembly it will not count the gallons and trip into a cycle.
  4. mrk431
    mrk431 New Member
    Jan 5, 2013
    Minneapolis
    I think it is on the six day. It has a wheel with six "pins". Every pin trips the recharge lever when I rotate the wheel. I know when we bought it, it was supposed to be a model that measured demand and recharged as necessary. I don't know what the meter dome is. There are no loose cables or connectors, although I suppose I should remove and re-seat all of them in case of corrosion. Picture attached:
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    That is one that has that $%^$^$%^$& aqua sensor to it... there is a way of changing that power head to where that sensor no longer has any part to play in the deal.
    It is most likely the reason that it is not doing it on its own and you have to trip it into a cycle.
    There has been at least one other person that has made the change over to the more simple unit.
    Also when was the lower piston assembly changed out? looks like there is leaking going on under the motor assembly, behind the tray with the white slider.
    Drop a pm if you would like.
  6. Maruchan Noodle
    Maruchan Noodle New Member
    Jan 11, 2014
    Tennessee
    I am having problems reinstalling the backwash timer assembly (pounds of salt and backwash time). Are there instructions on getting everything lined up properly and installing it?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    What are you working on reinstalling?
    What did you change?
  8. Maruchan Noodle
    Jan 11, 2014
    Tennessee
    See above...backwash timer assembly. 3 white round plastic pieces that nest together. The rod in the middle of them all is where the gear, pounds of salt and regeneration time selector screw into. Need to know the proper way to put this all together. Not changing anything just putting together
  9. Maruchan Noodle
    Jan 11, 2014
    Tennessee
    Seems like there is a special way to get the white pieces in with the relays so it doesn't spin around after I screw in the two selector pieces for the return time and pounds of salt
  10. Akpsdvan
    Dec 29, 2009
    Alaska
    The white cam on the back side of the timer that runs the micro switches.............. oh that is as mess if that gets out of wack.......some times the best way around that is to find a timer assembly and start over.
  11. Maruchan Noodle
    Jan 11, 2014
    Tennessee
    Great...so no repair manual or step by step on that?
  12. Akpsdvan
    Dec 29, 2009
    Alaska
    In the manuals that I have seen of Culligan I have yet to see a page with the timer break down.
    There is the motor replacement and the micro switches that can be replaced.
    There was one timer assembly that I replaced the trip switch on the front for starting a cycle but that was with out a book and having a used one on hand.
    The white cam on the back is kind of like the timer wheel for the Fleck 3200 timer assembly in tripping the micro switches. Fleck uses space and pins for the switches where culligan used the cam split in half and then turned so that the switches are tripped.
  13. Maruchan Noodle
    Jan 11, 2014
    Tennessee
    Every time I screw the selector to the cam it just spins...like something isn't right with the cam....sigh
  14. Akpsdvan
    Dec 29, 2009
    Alaska
    Could be that there is a stripped hole for the screw...
Similar Threads: Culligan Estate
Water Softener Forum, Questions and Answers Dead Culligan Estate 2 - How to remove & what's next? Dec 22, 2012
Water Softener Forum, Questions and Answers culligan estate 2 problems... water not soft Nov 16, 2012
Water Softener Forum, Questions and Answers culligan estate 2 water softner not working properly?? Jun 7, 2012
Water Softener Forum, Questions and Answers Culligan Medalist Series Model WG844 Mar 21, 2017
Water Softener Forum, Questions and Answers Culligan Mark 89 always draining Jan 7, 2017
