CSST Length
GoDillos
California
So, I'm planning to switch from an electric to a gas stove and planning to install the line myself. I'd really like to use flexible tubing if possible, but the only way I can find to buy CSST as a homeowner is to buy a prepackaged kit online. The kit comes with 25' tube, but I only need 12 - 15' for the run. Is there any danger to leaves the excess coiled in the basement?
Thanks
Chetwynd
California
fine
As long as the added length of CSST doesn't affect the load calculations (the ones that told you to use the size you're using), then there's no reason you can't have extra under there, as long as they're properly strapped to the underside of the floor joist. Obviously don't kink it trying to coil it! Good luck!
csst
I will have to check my installation manual, but I seem to remember a prohibition about installing it curled up, but that might have been for some other material. One problem could be humming if the curls are too small.
GoDillos
California
Thanks HJ. That would be awesome if you could check your manual. I was planning to make to coils about 12in diameter, but I could adjust according if the manual gives other suggestions.
