Here is information about toilet replacement of wall hung toilets at Crystal Chalets Condos.
Some toilets are original to the building and some have already been replaced. The original bowls use about six gallons, maybe more. There are two options that I have used for wall hung toilet replacement.
Norse Peak, 525 - 536
Crown Point, 513 - 524
Black Tusk, 501- 512
One is the Gerber Maxwell Wall Hung.
It's a gravity bowl with a 3" flush valve in the tank. It uses 1.28 gallons.
On a standard 4-1/4" rough from the floor, the bowl height is 16" high. About 1-1/2" higher than the Glenwall or the old existing bowl. Great if you like something a little higher as your knees age.
From wall to end of bowl it's 27"
The other is the American Standard Glenwall.
A pressure assist using the Sloan Flushmate at 1.6 gallons.
The bowl height is a standard 14-1/2" from the floor.
From wall to end of bowl it's 29-1/2"
Both of these bowls are elongated, and use a standard "elongated" seat.
The seat will add about 1-1/4" of height.
Reviews and pictures
I install a lot of these in the Seattle area.
I do add a trip charge for running up to Crystal and doing installations.
My mothers home in Bellevue has one of each. It gives me an idea of how well they work in the real world. I think it was a 60's thing having wall hung toilets. I see a lot of them.
