Crud in toilet
Discussion in 'Toilet Forum discussions' started by enosez, Apr 10, 2007.
  1. enosez
    enosez Member
    Jan 27, 2007
    Supv Maint Oper
    Long Island NY
    I have a Kohler Toilet that has a "jet" right before the trap way.
    There is a buildup of crud that has hardened coming out of this jet and right at the start of the trapway.
    I have tried using all kinds of toilet cleaners to remove it and nothing.
    Short of using a screwdriver to scrap it, I am hoping someone has had a similar experience and has an idea of how to remedy the situation.
  2. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    On the lighter side I hope the crud is not brown if your using a screw driver in there.
  4. zimmee66
    zimmee66 New Member
    Feb 28, 2005
    Des Moines, Iowa
    re: removing crud
    (Take this as non-pro advice...)
    I would assume the crud you are talking about is just lime minerals or possibly urine salts.
    I have had good results with using plain old distilled white vinegar (the kind you buy cheap at the grocery store in gallons) to disolve stuff like this.
    I usually turn off the supply water to the toilet and flush once to reduce the water in the bowl, then just pour the vinegar in. The less water in the bowl the higher the acid concentration in the vinegar, the better cleaning.
    Then let it sit a good while. if needed a little mechanical cleaning may be helpful (i.e. your screwdriver plan).
    Its harmless and cheap to try.
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I would clean that out with meuratic acid.........
Similar Threads: Crud toilet
Toilet Forum discussions Orange film/crud in bottom of American Standard Champion Dec 31, 2011
Toilet Forum discussions How is the toilet made the difference between 1.28 and 1.60 GPF toilet? Saturday at 9:18 PM
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Saturday at 9:06 PM
Toilet Forum discussions Toilet leaks than stops Thursday at 9:59 AM
Toilet Forum discussions Baffled! Replacing existing same toilet does not fit!! Wednesday at 8:51 AM
