Barrybpdx
i inherited a toilet rough-in that came out of the floor at an angle. i dry-fitted several different flanges and one of them seemed like it would slide down flat to the floor. but after i glued it up and took my foot off it, one side of the flange is on the floor but the other side is 1/4" or more off the floor. i set my Toto on it and the toilet isn't sitting tight to the floor.
taking up some floor / subfloor isn't out of the question but space is tight in the floor and i don't see that i can make the riser plumb.
my thought now is to flush cut the flange at floor level and use an inside flange. (when dry-fitting different flanges, the inside also sat tight to the floor.)
this is ABS, 3". it seems like reducing the size of the pipe isn't a great idea, but i measured and the inside diameter of the inside flange is still larger than the inside diameter of the horn on my Toto Drake.
so i should go for it, yes?
