crooked PVC toilet flange
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hdmstng, Jan 23, 2010.
  1. hdmstng
    hdmstng New Member
    Jan 8, 2008
    West Chester, Ohio
    I've been remodeling a bathroom and went to install the PVC toilet flange on and it set crooked! The right side is a hair off the tile but the left side is ~1/4 inch up off the floor. If I screw it down, the right side should be tight with the floor, but no way for the left side, still about 1/4" high. It is a PVC flange with a stainless steel ring that fits over a 3" PVC pipe. The 3" PVC pipe first into a 90 degree elbow.
    Can I shim the right side of the flange with plastic shims? Will a normal wax ring work? Then also use the shims when I install the toilet?
    Aren't there cutters designed to save the ID of the elbow and I can just cut out the entire thing and replace?
    Any suggestion on how to proceed?
  2. hj
    1/4" should be well within the parameters for setting the toilet. But if you screw the high side down you will probably find that it DOES pull down even with the floor.
  4. hdmstng
    hdmstng New Member
    Jan 8, 2008
    West Chester, Ohio
    Thanks for the quick response HJ. It will go down slightly, but I'm worried about the stress it will put on the rest of the pipes. Or will the stainless steel ring bend a bit? If not, I guess some shims under the stainless steel ring and for the toilet once it has been set to prevent rocking might do the trick.
  5. hdmstng
    hdmstng New Member
    Jan 8, 2008
    West Chester, Ohio
    You were right on target HJ! The stainless steel ring conformed much more than the PVC being pushed down and no shims were needed. I do realize what went wrong and why the piece went on crooked in the first place. The drain line had a bit of play in it, so when I went to cement the flange on, the entire assembly flexed not allowing it to set fully. In hindsight, some blocking underneath the elbow or strapping was needed. Hopefully others will learn from my mistakes.
Similar Threads: crooked toilet
Plumbing Forum, Professional & DIY Advice crooked toilet rough, flange not flat Mar 10, 2008
Plumbing Forum, Professional & DIY Advice Crooked/Angled PEX crimps Nov 19, 2015
Plumbing Forum, Professional & DIY Advice crooked connection - will it last? Oct 28, 2013
Plumbing Forum, Professional & DIY Advice Crooked slip joint..... Aug 14, 2006
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
