Crimped Supply Lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DMLane, Sep 14, 2005.
  1. DMLane
    DMLane New Member
    Sep 14, 2005
    I hired a plumber to install two bathroom sinks and faucets. I requested metal traps and hardware since these elements are exposed and not hidden inside cabinetry. Upon inspection, I noticed that the supply lines (chrome plated copper?) were considerably crimped during installation in order to coax the line into the proper position for hookup. Two of the lines have about an 85° angle and the chrome plating is now abraded. The water flow through the tap seems strong enough, but I worry about the integrity of the supply tubes being compromised and weakened at the bend. Is this a valid concern? Should I request that the plumber return to redo this work?
    Thanks in advance for your replies.
    DMLane
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    kink
    replace for sure..........
  4. hj
    pipes
    Are they actually "indented" crimped, or merely a gentle curve? A sharp bend will eventually crack at that point.
  5. DMLane
    DMLane New Member
    Sep 14, 2005
    re: pipes
    Hi hj. It's a very sharp bend with a crease and a flare-out of the metal. The chrome plating is also chipping off at the site. Should I request that he install braided stainless steel risers instead? What is the best material for this component? Thanks in advance for your help, hj.
    DMLane
  6. hj
    supplies
    The problem most people have with the braided supplies on a pedestal lav is that they are a fixed length, and so they have to be looped or twisted to use up the extra length. There are some made with a section of copper tubing that can be cut off and eliminate that problem, but they are not a normal stock item with most suppliers. He should use a tubing bender if he is going to install the chrome risers.
  7. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    to be honest
    i question, weather the person that left this, has it in them to do a proper job! hire for attitude, train for skill, is how i work. there isn,t much of that anymore! sorry i,m rambling again. good luck
  8. DMLane
    DMLane New Member
    Sep 14, 2005
    re: supplies
    Thanks for the explanation, hj. I'm not too keen on looping or twisting, so I'll be prepared to inquire first about length. Your replies have been a big help.
    DMLane
  9. DMLane
    DMLane New Member
    Sep 14, 2005
    re: to be honest
    Hi toolaholic. Yes, I question his commitment to quality at this point also. You are so right to hire for attitude, for that cannot be taught. Thanks for your reply.
    DMLane
  10. DMLane
    DMLane New Member
    Sep 14, 2005
    re: kink
    Hi plumber1. Thanks for your reply. They will be replaced tomorrow. :)
Similar Threads: Crimped Supply
Plumbing Forum, Professional & DIY Advice Crimped copper connections? Feb 4, 2006
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Sunday at 1:46 PM
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Feb 20, 2017
