Crawlspace cleanup
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Billyblackxz, Feb 11, 2008.
  1. Billyblackxz
    Billyblackxz New Member
    Feb 11, 2008
    California
    Hi-I just discovered a leaky galvanized drain pipe under my home.I have since replaced it with black PVC but now have 3-4 places where there are pockets of dirty,stinky standing water.I have cement pier blocks where water is sitting;probably for the last 2-3 weeks.What would be the best way to get this water out of there and what should be done with the moist clay soil?Any help is greatly appreciated!!
    Steve
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Pour lime on it!
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    And then bury it with sand.
    Mike
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    And then cover it all with visqueen to avoid dry rot.
  6. mattt19
    mattt19 New Member
    Dec 22, 2007
    wow - I had almost the exact same thing happen to me. I bought a small pump from home depot and pumped the standing water out. After I pumped all the water out I set up several fans to help dry things out.
  7. MG
    MG New Member
    Jun 29, 2005
    Illinois - Near St. Louis
    Cat litter? It is designed to pickup moisture and deal with odor.
  8. Billyblackxz
    Feb 11, 2008
    California
    Hi Guys-Thanks for the advice;looks like everything is ok!!:D
    Steve
Similar Threads: Crawlspace cleanup
Plumbing Forum, Professional & DIY Advice Methods for cleanup house drainage break water/mud from under crawlspace May 17, 2011
Plumbing Forum, Professional & DIY Advice Drain Line Repair in Crawlspace - am I being over quoted? Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Waterproof enclosure for PEX manifold in attic crawlspace? Nov 17, 2014
Plumbing Forum, Professional & DIY Advice 80% humidity in Crawlspace Aug 3, 2012
Plumbing Forum, Professional & DIY Advice Is this cost estimate Reasonable? Repipe waste in crawlspace Jul 10, 2012
