Crawl Space
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ton, Oct 9, 2009.
  1. ton
    ton New Member
    Jul 3, 2008
    Good day
    Thank you for this site its great. I am located in northern ontario. coldest temp with be -40f. My crawl space contains all my pex water lines. Pump and hot water tank is in the cottage. I would like to use the place in the winter on occasion only. I have intention of closing in the crawl space (26x26x2ft height) and insulate it if need be to shelter it from winds.
    Question is do I heat trace my lines less insulation on perimeter walls
    or
    Heat the crawl space thermostatically at 36 to 40 degree F (baseboard heaters fasten to joists) to prevent water lines from freezing and leave pex lines as is. In this case i would be insulating the permimeter walls (vapor barrier and all) Help would be appreciated
Similar Threads: Crawl Space
Plumbing Forum, Professional & DIY Advice Drain Line Repair in Crawlspace - am I being over quoted? Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Risk of cutting galvanized where it enters the crawl space May 11, 2016
Plumbing Forum, Professional & DIY Advice Crawl space drain - backed up Jan 24, 2016
Plumbing Forum, Professional & DIY Advice Building a bathroom on an unheated crawl space Sep 21, 2015
Plumbing Forum, Professional & DIY Advice Crawl space wet Sep 15, 2015
