Crawl Space HVAC
Discussion in 'HVAC Heating & Cooling' started by weather777, Nov 3, 2008.
  1. weather777
    weather777 New Member
    Sep 30, 2008
    HVAC was located in the crawl space of new construction(see below),but there is concern as to noise potential at night with a bedroom above.Please provide thoughts as to noise as well as possible solutions---there is a mechanical room on floor above,but HVAC person did not want to use it.The crawl space will be sealed (and conditioned) with foam above and other materials on walls and floor.
    Thank you for your help
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Rule 1 - Never locate mechanical equipment near the master bedroom.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Unless your house is located next to a busy interstate highway or, rail line...
    Then it probably doesn't matter...
  5. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    Imagine that, the HVAC professional took it upon himself to usurp the house designer. Call him back and tell him to do the job right or you'll call your attorney.
  6. weather777
    Sep 30, 2008
    We agreed to it after hearing it would not work in the mechanical room as thought ---so I blame myself for it.:(
  7. Southern Man
    Jun 27, 2008
    North Carolina
    Most of the noise will come from the unit being attached to the I-joists. If you support it on the ground that will all go away.
    Get out the install manual for the thing and locate the lower support points. Then get yourself a dozen or so concrete blocks, some pressure treated lumber, a short shovel and your old clothes. Dig a footing under the unit to the frost line and stack up the blocks to a few inches of the unit's support points. Cut plates from the lumber to bridge over the masonry cells and cushion the unit. Then drop the unit down onto the new support, making sure that you've got plenty of slack in the flexible duct connections and the condensate still drains.
    You can also get a roll of unfaced fiberglass insulation and add it to what you already have between the joists above the unit.
Similar Threads: Crawl Space
HVAC Heating & Cooling Flexible Duct in Narrow Crawlspace Sep 23, 2016
HVAC Heating & Cooling mystery vent in bathroom floor above crawl space Nov 29, 2013
HVAC Heating & Cooling Rh Puzzle in Encapsulated Crawl Space Feb 21, 2013
HVAC Heating & Cooling Hanging refrigerant/vapor line in crawlspace Oct 23, 2012
HVAC Heating & Cooling HVAC height requirement in crawlspace? Aug 18, 2012
