gregh
Hi All,
About 3 years ago, We had a drain added for a washing machine inside the house. It was added into the drain line for the sink/garbage disposal with a "y" valve. Recently, I noticed that water is backing up more and more into our sink and takes 10-15 minutes to drain. After doing some inspection and troubleshooting, it looks like the install is causing the problem. The "Y" joint with the washing machine is now sagging and there is quite a bit of build up due to improper drainage (3 years worth). I've tried a garden hose with pressure, using a pipe auger, and a few other methods under the house with no luck. My next inclination is to cut a section of the pipe out where the clog is, remove the clog, and add strapping, etc to let gravity correct the problem. Any advice appreciated.
